There's no meters in either circuit. The first is a current source in parallel with it's output resistance and the second is an equivalent voltage source in series with its output resistance.the ampmeter is not placed across the load, the first drawing is wrong. in the second drawing, the voltmeter is in series with the load, that is wrong. measure3 amps in series with the load, and volts across the load.
Thank you for the reply!This looks like homework-related, so probably should have been posted in the Homework Help forum.
The quality of the schematic is more than adequate -- but that all people would post something as good (or at all).
Also, thank you for posting your attempt at a solution. Very rare and very appreciated.
Finally, yes, your transformation is correct. The resistor could have gone in either the top or the bottom (or the left) branch. Also, you could have swapped the polarity of the voltage supply and then specified the voltage as -12V. All of them are equal. By convention, a circuit such as this would typically be drawn with a voltage source that has the negative terminal at the bottom and (and so would have a value of -12V) and the resistor would be in the top branch. But that is purely by common convention because that's what people are used to seeing. It is technically correct as you have drawn it.
But isn't in that case current can't flow to the resistor because + side is on the opposite side of the resistorYes, this transformation is also correct.
I don't get what you are trying to say?But isn't in that case current can't flow to the resistor because + side is on the opposite side of the resistor
Thread starter | Similar threads | Forum | Replies | Date |
Source transformation principle - I am doing something wrong. | Homework Help | 4 | ||
A | Source transformation | Homework Help | 4 | |
H | Source Transformation Question | Homework Help | 1 | |
W | Help identifying mistake in source transformation problem | Homework Help | 4 | |
Small question about source transformation | Homework Help | 6 |
by Jake Hertz
by Aaron Carman
by Jake Hertz
