Is my math corecct? Please help.
Discussion in 'Math' started by 1213brett, Feb 9, 2015.
  1. 1213brett
    Feb 1, 2015
    13
    I'm trying to find out if my mosfet needs a heat sink. my load draw 1.20 A and im triggering the mosfet with ardino pin 7 5V
    P= current squared * RDS
    1.20 A * .16 Ohms squared = .2302
    TJmax - Tambient / ROJA
    150 - 25 / 62 = 2.02
    2.02 is larger then .2302 so I need a heat sink
  2. ScottWang
    Aug 23, 2012
    4,930
    777
    How is your load V/I, do you have a circuit?
    You can choosing some other mosfets has lower Rds then it could reducing the power consumption.
  3. Magician
    Aug 18, 2014
    13
    6
    No, you don't. MOSFET is o'k up to 2W w/o heatsink, and it's needs to dissipate 0.23W. Are you using PWM? Losses may be more in case PWM
  4. 1213brett
    Feb 1, 2015
    13
    No I'm not. And thank you!
  5. WBahn
    Mar 31, 2012
    18,087
    4,917
    Note that
    150 - 25 / 62 = 149.60
    Remember order of operations!
    If you mean (150 - 25) / 62, then say so.
    Also, use your units and your answer becomes much more informative:
    Pmax = (TJmax - Tambient)/ROJA = (150 °C - 25 °C)/(62 °C/W) = 2.02 W
    Pactual = I²·Rds = (1.2 A)²·(0.16 Ω) = 0.23 W
    Since Pactual < Pmax, no heat sink needed.
  6. uwed
    Member
    Mar 16, 2015
    64
    17
    Rds=0.16 ohm is usually normalized (room temperature). If you operate at Tj=150°C we would have Rds=2.2*0.16=0.35ohm (see Fig.4 in the datasheet).
