Is it possible to transmit/boost an 850mhz signal over home ac wiring?
Discussion in 'The Projects Forum' started by gte, Jun 9, 2010.
  1. gte
    Thread Starter Active Member
    Sep 18, 2009
    347
    Any ideas or schematics that could be looked at? Or just general theory?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. coldpenguin
    Apr 18, 2010
    165
    9
    I think that this is wired, not wireless isn't it?
    Or do you think that the phones will still interfere?
  4. Bychon
    Member
    Mar 12, 2010
    469
    41
    The wiring will act like a big transmitting antenna. Maybe not enough to interfere, but caution is recommended.
  5. gte
    Sep 18, 2009
    347
    It is meant to be wired.
    I need to bring cell service (verizon) into a dead spot where other options such as the network extender and a large external antenna are not viable options
  6. retched
    Dec 5, 2009
    5,201
    313
    The thing is, you will be able to bring the signal to the phone, but you will also need a way to take the transmitted phone data and get it to the outside world.
  7. gte
    Sep 18, 2009
    347
    Hi
    If the signal was duplex and the other end of this 'circuit' was in an area of good reception, wouldn't it work as if I was in an area of good signal?
