Is it possible to increase static electricity distance ?
Discussion in 'General Electronics Chat' started by jeolex, Jan 26, 2016.
  1. jeolex
    May 3, 2015
    23
    Hi my friends,
    I have negative ion generator. I have used it for generating static electiricity and I have done it. I can pull some slices of paper, stick etc. by static electricity. But pulling distance is not enough for my project. It is about 2-3 cm. Is it possible to increase the pulling distance of static electricity to approx. 10 cm ?
    You can see my items from here
    And also want to ask that have high voltage generators capable for producing static electricty ?
    Thanks,
    Best regards.
  2. KL7AJ
    Nov 4, 2008
    2,047
    295
    If you're serious about high voltage, you want to buy or build a Van de Graaf generator. Edmund Scientific has some pretty decent ones.
    jeolex likes this.
  3. jeolex
    May 3, 2015
    23
    I have ordered high voltage generator (400 kV). I supposed that it will generate more powerful static electiricty than what I have (4-6kV).
    Ordered high voltage generator here, I am not sure it is capable to produce static electiricity.
  4. mcgyvr
    Oct 15, 2009
    4,791
    976
  5. KL7AJ
    Nov 4, 2008
    2,047
    295
    "Static" only refers to the way it's made.....it's still the same stuff.
    jeolex likes this.
  6. jeolex
    May 3, 2015
    23
    Thanks for replies. Sorry for my lack of electricity knowledge.
    I also wonder that for example I connect both of terminals which are make arc to aluminium plates and generate static electricity area between plates, what s that mean. Is that mean when I put something between two plates, this thing exposure "-" negative ion ? How is possible that pull or move light materials such as slice of paper, dusts, sticks etc. in static area.
    Thanks,
    Best regards.
