Is it possible to havea solderless circuit?
Discussion in 'The Projects Forum' started by yeto, Jul 11, 2011.
  1. yeto
    Jul 3, 2011
    12
    I want to build a small, ic chip based, guitar amp that will have interchangeable modules. Does a part exist that would allow me to plug an ic chip into a socket with wires extending that I could then connect to a spring loaded clip connection box? In other words, what are the best connection devices to use to build a circuit without using solder (I guess something like a bread board)?
    Thanks,
    yeto
  2. MrChips
    Oct 2, 2009
    12,635
    3,453
    You can use wire-wrap sockets.
    Also Scotch 3M used to make a solderless breadboarding system.
  3. DickCappels
    Aug 21, 2008
    2,772
    669
