Depends. If it has a crossover network inside, the woofer is only being fed low frequency signals.Is it possible to change a woofer speaker to a tweeter speaker for ultrasonic purpose ?
Bravo, This is what I had found it out before ( replacing the paper cone with a slim foil metal cone and deleting the rippled cloth which speaker coil is installed on it ) but I doubted and intended to question.Remove the paper cone and associated metal structures and use only the magnet assy+voice coil(spyder) portion of the speaker. Place something structurally similar to one half of a ping pong ball, but suitably larger, over the coil assy. Something very light, and very stiff. Then it would begin to behave and sound more like a high freq horn driver.
I don't see what purpose would that serve, you will not get louder high frequencies by damping the speaker even more.Also I have another simple idea but don't know whether it works or no. Is it possible we put a flat spring ( in the shape of cone) on the paper cone to limit its shaking (frequency) ?
by Jerry Twomey
by Jeff Child
by Robert Keim
by Duane Benson
