is it possible for using connecting 8 UART externally to PIC
Discussion in 'Embedded Systems and Microcontrollers' started by dark dragon, Jul 12, 2010.
  1. dark dragon
    Dec 11, 2008
    13
    can i able to connect 8 UART with PIC 16Fxxx
    and make it to work almost simultaneously
    wat should i do for that is there any special device need for tat like latch r something
    also tell me the IC name for UART suitable for such application
    r shall i go for i2c
    i'm in confuse how to select the IC...
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Yes it is possible to connect an 8 channel UART to a PIC. Depending on the baudrates on the individual channels you may or may not be able to handle the traffic reliably. Some FIFO buffering on each channel should help.
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I do not answer emails from forum participants. I prefer to answer in the forum so everyone can benefit. Your question was how to connect 8 UARTS to a PIC16xxx. I would start by reviewing the following datasheet:
    http://www.nxp.com/documents/data_sheet/SCC2698B.pdf
    Can you see how to do it from this datasheet and the one for the PIC variant you are interested in? Your biggest challenge will be dealing with the limited amount of file registers inside the PIC16xxx for 8 UARTS.
    Also, I could do the design for you. How much is it worth? Ohhh...you want me to do it for advertising. Sorry not interested. I'll help you but I won't do it for you: at least not for free.
  4. dark dragon
    Dec 11, 2008
    13
    hey i just mailed u ly coz i didnt get any proper response for my posts
    so ly i privately approached u nothing else..
    also if i want to give it to others i can buy it market y i come to here..
    i want to learn something from good guys like u and solve at lest one forum participants in future..
    NOW COMING TO SUBJECT
    i'm new to this field with my friends..
    trying to do also i do..
    thanks for ur reply to me..
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    You will get more and better responses if you show that you have made some effort. I don't think there are many cases where somebody asks for something and has it handed to them. Being new is OK, but not showing any effort in your posts will get you ignored or worse -- scorned.
  6. dark dragon
    Dec 11, 2008
    13
    hey my actually doubt is i'm using these UART for receiving data (not too large just a 4 byte)
    for wireless remote control operation..
    (but different wireless techniques eg.IR RF so using multiple uart )
    if i connect tat and i program tat is it enough..
    or some special i have to take for stuff
    coz i very new to field and no practical knowledge..
  7. Papabravo
    Feb 24, 2006
    10,340
    1,850
    That should be fine
