Gauge on the cover reads 20.What diameter or gauge is the solder ?
2. Yes, the pack says 60/40 and not lead free solder.Ok, that's good. Let's go through the steps.
1. You are using resin core solder.
2. Know the type of solder you are using. Lead free solder is trickier to work with than 60/40 solder. I don't know the regulations in India about using leaded solder.
3. What brand/model soldering iron are you using? Is it the right temperature. 60/40 solder requires 700F.
4. Is the soldering tip bright and shiny? If not you have to clean it and tin it with solder.
5. As others have already mentioned, make sure all corroded, discoloured or tarnished metal is cleaned first before soldering.
6. Are you heating the joint and not the solder? This is the single biggest mistake. You must heat the component leads, joints and solder pads in order for to solder the flow. While the soldering tip is still in contact with the leads and pads, touch the solder wire where the soldering tip meets the component leads. The solder should melt and flow across the joint. Melt enough solder to flow across the joint, no more. Hold the soldering tip there for three seconds and then remove. Allow to cool for 5 seconds without disturbing.
by Jeff Child
by Aaron Carman
by Aaron Carman
