Bad news. I replaced the triac and the zener diode, I tested the voltage across the zener, it is 18V. When I turn the unit on the led flashes one time only and the resistive loads don't heat up.. there is no voltage across them. I tested the voltage at the IC output that is connected to the gate by an oscilloscope and found no voltage. So there is a DC voltage on the IC and there is no output voltage. I think the IC is bad. I can't get another IC... I tried to disconnect the sensor but it didn't work too. Disconnecting the sensor means it's resistance is infinite, maybe it's a PTC and not NTC? then what should I do? connect the sensor terminal with COM and try?
