Is generating a freq the same as generating a tone?
Discussion in 'General Electronics Chat' started by sciguy77, Dec 15, 2012.
  1. sciguy77
    Dec 15, 2012
    I'm trying to record analog values with a digital recorder. Basically I have a recorder and have 2 leads connected via the mic port. If I just apply regular voltage to the leads the recorder doesn't recognize the external mic and records with the internal mic. It seems as though the recorder will only read values through the external mic if there is a tone going through it. I know the Arduino can generate tones, but if possible I'd like to do this with a simple voltage to frequency converter IC like the Texas Instruments LM231 (http://www.ti.com/lit/ds/symlink/lm231.pdf). My question is: if I convert voltage to frequency, is that the *same* thing as generating a tone (will it be readable)?
    Thanks!
  2. tubeguy
    Nov 3, 2012
    1,157
    197
    A frequency is considered a 'tone', ie tone generator.
    And yes, the recorder will not record steady voltages, only frequencies within its frequency range.
    For more help you should be more specific about what your final goal is.
    What will you do with the recording?
  3. sciguy77
    Dec 15, 2012
    My recorder can display audio waves in real time when connected to a computer. By translating dc voltages to tones I hope to make myself a cheap and quick oscilloscope without having to buy one of the expensive ones. Mostly just for fun though TBH.
  4. BillB3857
    Feb 28, 2009
    2,402
    348
    This is only one of many links to a PC based scope.
    http://www.zen22142.zen.co.uk/Prac/winscope.htm
    Frequency is limited since it uses the sound card in your PC. You will want to insure voltages do not exceed limits of your sound card input.
  5. Externet
    Nov 29, 2005
    781
    58
    The word tone is mostly used for an audible frequency.
    All the rest are frequencies of varied nature, as a sea waves, earthquake waves, resonance waves, electrical waves, magnetic waves, light waves, radio waves...
