yes, i've just learned that too. the sidebands are actually needed to reconstruct the original audio accurately. They extend infinitely in both directions, but in the real world you're limited by your available bandwidth. So, FCC "allotted bandwidth" includes not only your deviation range, but also the sidebands! That's a new insight for me. Therefor, the receiver must be demodulating the whole complex waveform containing the sidebands, not just the sinewave at transmission freq. Wow.
http://www.radio-electronics.com/in...reception/fm-slope-detector-discriminator.php"mechanism which allows you to "slope tune" an AM receiver to listen to FM signals."
what!? ok, i'm going to have to research that.
http://www.rdlnet.com/downloads/articles/am_noise_article.pdf"AM Noise is not a great problem with PLL detectors,but with Ratio Detectors & the like which convert FM to AM so as to detect it,this can be a major source of received noise."
ok, thx, i'm thinking PLL.
"The loss of information still affects all types of detectors,though,appearing as distortion."
thx, very helpful..
I did say "2x deviation",which for 5kHz deviation would be "roughly"10kHz occupied bandwidth at the radiated frequency."2x Deviation is a fair "rough guide" to deviation for narrowband FM,but is not the whole story in the wideband case."
2x what? the highest freq in your source audio?
commercial broadcast FM is considered wideband, right?
I made this point because it is often quoted by folk who have spent their working lives with narrowband Comms equipment.
It is just a rough guide,& isn't strictly correct,even for narrow band FM.(NBFM)
Yes,Broadcast FM is wideband (WBFM)
The Maths aren't all that hard to learn,so I recommend you do so.This article goes into detail about how to calculate deviation, and talks about sidebands. I don't understand the math.
http://www.silabs.com/Marcom Documents/Resources/FMTutorial.pdf
The downside is they aren't hard to forget,either,till you get to the point where I am now---I look at it ,& say:-"Yeah,that makes sense",but I would struggle to work through it.
Just for now,try "reading around" the Maths,as there is still a lot of good stuff in the text.
If you can get your hands on an ARRL Handbook ( your local Library may have one),they have some good stuff."The dynamic range of any radio system is the ratio between the maximum modulating signal level & the minimum modulating signal level which it can reproduce at the receiver end of the system."
Yes. Ie, difference between the loudest sound and quietest reproducible sound.
"Analysis of FM modulation is not something which you can do on the basis of a few paragraphs in this forum. You need to do your own research"
I'm continuing to read everything i can get my hands on, but there's a lot i don't understand. I come to forums to get help where i don't understand the research.
"I haven't done any serious study in this field for about 30 years,so you have pretty much "wrung me dry".
i highly doubt that, you're a great resource.
thx]
In my (2001) edition.in Chapter 12" Modulation Sources (What and How We Communicate)",
There is a section on FM,which includes the useful & interesting Bessel Function graph.
Read it in conjunction with the section "Mixers & Angle Modulation" in Chapter 15 "Mixers,Modulators & Demodulators"
Of course,the Chapters may be different in newer issues,in which case,you will have to search through the book to find them.
The Chapter Index at the front of the book is good--the main index at the back is quite hard to navigate.
