Is an always ON npn transistor bad design?
Discussion in 'General Electronics Chat' started by tpny, Dec 9, 2012.
  1. tpny
    May 6, 2012
    216
    If my npn is always turned ON (fully ON) and only occassionally turned OFF (by pushbutton), is that a bad design?
  2. #12
    Nov 30, 2010
    16,705
    7,358
    No.
    absf likes this.
  3. WBahn
    Mar 31, 2012
    18,093
    4,920
    Not inherently. Depending on the goal of the circuit, it may even be the best way to achieve something. But, it may also be a poor way. For instance, another approach my reduce average power consumption. Again, it depends on what you are trying to do and what aspects are more important than others.
  4. absf
    Dec 29, 2010
    1,493
    374
    Lots of design have transistors turned on when on standby. Eg your TV or else the remote control would not work. Your PC is also running with a standby +5 volts feeding the PSU so on pushing a push button you and trigger on the PC without having the mains switched off.
    Important thing is the transistor that was always switched on doesnt consume too much current..
    Allen
  5. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    It's a bad question because it can not be answered.
    It's not totally unlikely that it is neither a good nor a bad design and simly does not matter.
    If you want an answer the circuit must be shown.
  6. dataman19
    Member
    Dec 26, 2009
    136
    29
    That depends...
    Do you think the fact that the commercial power line is always on -s wasting electricity?
    Dave
    Phoenix, AZ
    absf likes this.
