Irregular shaped coil in electromagnetism
Discussion in 'Physics' started by pjreijiri, Aug 29, 2016.
  1. pjreijiri
    Aug 19, 2015
    60
    hello everyone,
    I have a question about electromagnetism.
    If we have a magnet and we moved it “in” and “out” of a non-circular shaped coil, would it still create the same current/voltage?
    and if we have more than 1 magnet (all faced in the same direction) how would that affect the current and voltage?
    You can check the attached picture for a more clear representation.
    Regards
  2. AlbertHall
    Jun 4, 2014
    2,277
    449
    If a wire is in a changing magnetic field then a current will be induced in that wire.
    Multiple magnets with the same polarity inside the coil will increase the effective magnetic field.
  3. pjreijiri
    Aug 19, 2015
    60
    So the shape of the cross section of the coil is not a problem.
    Is there a different way in getting the voltage and current across and through the coil than the circular coil?
    Thank you
  4. AlbertHall
    Jun 4, 2014
    2,277
    449
    I don't understand what you are asking here. Connection of a voltmeter and/or ammeter does not depend on the shape of the coil though the voltage and current will probably vary depending on the shape and how it relates to the magnetic field.
  5. DGElder
    Member
    Apr 3, 2016
    347
    87
    In a uniform magnetic field the voltage induced in a closed loop is proportional to the rate of change in the cross sectional area of the loop perpendicular to the magnetic field. The shape doesn't matter. Look up Faraday's Law.
  6. AlbertHall
    Jun 4, 2014
    2,277
    449
    Except the field will not be uniform.
  7. pjreijiri
    Aug 19, 2015
    60
    Do you think, I make an assumption of turning the area to a circle and multiply the flux generated by one magnet by the number of magnets that I have?
    At least to get a feel of where to start
  8. DGElder
    Member
    Apr 3, 2016
    347
    87
    Probably, but since we have no context or specifics for these questions it just looks like another XY problem.
    http://xyproblem.info/
  9. pjreijiri
    Aug 19, 2015
    60
    I have a shape similar to the onei attached earlier. It has 7 magnets each are N45 30mm diameter and 4mm thickness. The area of the loop is around 0.02m2 and the magnets are around 21mm from the edge
  10. wayneh
    Sep 9, 2010
    12,391
    3,246
    What's missing, if you want a quantitative answer, is the geometry of the field lines and the strength of those lines. Magnetic field lines are a bit like a circuit, in that they have to form a closed loop to the other pole of the magnet. If they make a big arc through air or vacuum (both of which have very low permeability), the situation is very different than if they are attached to a steel structure (which has a high permeability) that nearly closes the circle and tightens any air gap. The field lines cutting through the loop would be much stronger in that latter case.
    This all said, it can be very difficult to make quantitative predictions involving magnets. A little experimental data may be far more useful.
