The pull-down resistor holds the gate low when the micro-controller is not driving it (such as when it is first booting up and the pins haven't been setup yet). Otherwise the gate can (and probably will) "float" high and turn on the MOSFET.Ok then! Thanks!
I still don't understand what that does?
Just insert the LED with an appropriate series resistor between the trigger signal and ground.Sorry, I have another question!
If I wanted to have small LED that lights up when the +5V 'trigger' signal is present,
how would I connect it, so it doesn't draw too much power(and keeps the MOSFET
from its full potential) ?
Thanks!
by Jake Hertz
by Aaron Carman
by Jake Hertz
by Jake Hertz
