IRFR310, IRFU310, SiHFR310, SiHFU310
Discussion in 'General Electronics Chat' started by NY10, Aug 31, 2010.
  1. NY10
    Jul 30, 2010
    47
    Hi, all
    I am trying to find these spice models, but I could not find them.
    These power MOSFETs are manufactured by VISHAY and I contacted them, let them know that it seems these parts do not have spice models. In addition, I asked them if they know where I can find them.
    In response, they said since these parts are legacy, therefore the spice models exist.
    They did not tell me where I can find the spice models, but kept saying the spice models exist.
    Does anyone know where to find these spice models ? Can anyone point me to the right direction ?
    Thanks.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Intusoft's ICAP/4Rx Power Deluxe library has a model for the IRFR310.
    http://www.intusoft.com/products/ICAP4RxPower.htm
    Neither the library nor the model is available separate from the package.
    Apparently, they have some demo versions available, but I have no idea if that model is in any of their demo versions.
  3. NY10
    Jul 30, 2010
    47
    thanks for the reply.
    I went to see the files, but it looked like they were not spice models. Basically, they made excel spreadsheet to list the parts such as description, manufacturer, etc.
    Basically, they were irrelevant. It was not something that I was looking for.
    Thanks for trying.
  4. marshallf3
    Jul 26, 2010
    2,358
    201
    While spice simulation is far from new there just aren't going to be models for everything, often one has to g=find whatever is the closest and use that.
    I've got the same problem inmy PCB design & layout program, the libraries are limited and sometimes you've got to create your own for a particular component.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Here's Vishay's page for the IRFx320:
    http://www.vishay.com/mosfets/list/product-91273/
    Not identical, but it's close (Lower Rds(on), same Vdss, higher gate charge)
    The model for those is available on the page. Since it's in UNIX format, here it is in ASCII:
    Code ( (Unknown Language)):
    1. .SUBCKT irfru320 1 2 3
    2. **************************************
    3. *      Model Generated by MODPEX     *
    4. *Copyright(c) Symmetry Design Systems*
    5. *         All Rights Reserved        *
    6. *    UNPUBLISHED LICENSED SOFTWARE   *
    7. *   Contains Proprietary Information *
    8. *      Which is The Property of      *
    9. *     SYMMETRY OR ITS LICENSORS      *
    10. *Commercial Use or Resale Restricted *
    11. *   by Symmetry License Agreement    *
    12. **************************************
    13. * Model generated on Jun 25, 96
    14. * Model format: SPICE3
    15. * Symmetry POWER MOS Model (Version 1.0)
    16. * External Node Designations
    17. * Node 1 -> Drain
    18. * Node 2 -> Gate
    19. * Node 3 -> Source
    20. M1 9 7 8 8 MM L=100u W=100u
    21. * Default values used in MM:
    22. * The voltage-dependent capacitances are
    23. * not included. Other default values are:
    24. *   RS=0 RD=0 LD=0 CBD=0 CBS=0 CGBO=0
    25. .MODEL MM NMOS LEVEL=1 IS=1e-32
    26. +VTO=4.15933 LAMBDA=0.000873656 KP=1.20958
    27. +CGSO=3.69055e-06 CGDO=1e-11
    28. RS 8 3 0.0001
    29. D1 3 1 MD
    30. .MODEL MD D IS=1.15747e-11 RS=0.046973 N=1.24752 BV=400
    31. +IBV=0.00025 EG=1.2 XTI=1 TT=0
    32. +CJO=3.10831e-10 VJ=5 M=0.9 FC=0.5
    33. RDS 3 1 1.6e+07
    34. RD 9 1 1.1881
    35. RG 2 7 2.34569
    36. D2 4 5 MD1
    37. * Default values used in MD1:
    38. *   RS=0 EG=1.11 XTI=3.0 TT=0
    39. *   BV=infinite IBV=1mA
    40. .MODEL MD1 D IS=1e-32 N=50
    41. +CJO=7.11688e-10 VJ=1.11401 M=0.9 FC=1e-08
    42. D3 0 5 MD2
    43. * Default values used in MD2:
    44. *   EG=1.11 XTI=3.0 TT=0 CJO=0
    45. *   BV=infinite IBV=1mA
    46. .MODEL MD2 D IS=1e-10 N=0.400999 RS=3e-06
    47. RL 5 10 1
    48. FI2 7 9 VFI2 -1
    49. VFI2 4 0 0
    50. EV16 10 0 9 7 1
    51. CAP 11 10 7.11688e-10
    52. FI1 7 9 VFI1 -1
    53. VFI1 11 6 0
    54. RCAP 6 10 1
    55. D4 0 6 MD3
    56. * Default values used in MD3:
    57. *   EG=1.11 XTI=3.0 TT=0 CJO=0
    58. *   RS=0 BV=infinite IBV=1mA
    59. .MODEL MD3 D IS=1e-10 N=0.400999
    60. .ENDS
    61.
    62.
  6. NY10
    Jul 30, 2010
    47
    thanks.
    I already looked through Vishay website to find similar models, but it does not seem like they have what I am looking for.
    I decided to go IRF730 since I could find a spice model as well as it is close to IRFD310.
    However, I still want to have IRFD310 spice model since IRF730 have different package.
    Anyway, please let me know if you find something similar.
    Thanks as always.
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I've already told you where you can get the model.
    Try downloading a demo of Intusoft's ICAP/4Rx Power Deluxe.
    I seriously doubt that you will find that exact model just floating around on the Internet.
