I am currently working on a project wherein I am building an H-bridge using 2 IR2304 half-bridge drivers, with 4 IRFPA460As as my MOSFETs. Right now, I'm building and testing the circuit at low voltage, with an H-Bridge bus voltage of 20V. Eventually, that bus will be 170V (hence the beefy MOSFETs). My VCC is 10V as well.
My two bridges are wired exactly as in the IR2304 datasheet, with boot-strap capacitors of 100nF, and input filter capacitors of 0.01uF.
My input signal is a PWM signal which goes from 0V low to 10V high, with a 50kHz switching frequency, and the sine-wave which the PWM encodes is 60Hz. The circuit seems to be working at this point except for a strange problem. Occasionally, the HO of the bridge which is currently high duty cycle cuts off, and anywhere between one and 3 or 4 high cycles will stay low, before the gate begins switching high again.
One half-bridge is doing it worse than the other, but both are doing it. All I can think of as a reason is that for some reason, the shoot-through prevention logic is kicking in once in a while. It does seem to happen more when each H-bridge is high duty cycle, but it also happens sometimes around 50%. It never seems to happen below 50% though.
Anyway, any help with this issue would be greatly appreciated.
Ian
Ian
