Ir2130
Discussion in 'The Projects Forum' started by aqeel1, Jun 3, 2013.
  1. aqeel1
    May 30, 2013
    10
    i am working on DSP chip number IR2130 to design controller for bldc motor,
    at first the PWM controller then the chip ir2130 is connected to the 3-phase inverter.
    am i doing the right thing or i have to add other circuits also.
    There is another chip TMS320LF2407A, that i have searched on the internet but it is very complex to understand, is it necessary to connect this chip with my controller.
    Thanks.
  2. kubeek
    Sep 20, 2005
    4,691
    806
    You seem a little lost. IR2130 is a mosfet driver for a three phase bridge, and the TMS320LF2407A is a DSP microprocessor. Where are you getting the pwm from?
  3. aqeel1
    May 30, 2013
    10
    kubeek.
    yeah i am lost and confused, can i use only IR2130 for all the work or i have use TMS320LF2407A also with it....? if i have to use both....... ?????
  4. kubeek
    Sep 20, 2005
    4,691
    806
    You didn't answer my question, what generates the pwm?
  5. shortbus
    Sep 30, 2009
    4,098
    1,699
    A micro controller or DSP is not needed to control a BLDC motor with hall sensors, like you were talking about in your other thread. It can be done with a chip and the mosfets.
    The chip, MC33035 is very inexpensive to buy and old enough to be well proven to work.
    http://www.onsemi.com/PowerSolutions/product.do?id=MC33035
  6. aqeel1
    May 30, 2013
    10
    TMS320LF2407A generates the pwm.
  7. kubeek
    Sep 20, 2005
    4,691
    806
    Then you need both the TSM320 and the IR2130.
  8. aqeel1
    May 30, 2013
    10
    just connect 3-phase inverter with MC33035 chip and thats it..? any other components need to connect with it...... please don't get frustrated.
    thanks,
  9. shortbus
    Sep 30, 2009
    4,098
    1,699
    Not frustrated just don't understand why some one asks for help, but won't do what is suggested.
    Nothing this technical can be explained in 140 characters or less. You have to do the reading to understand what is needed. Don't think you have figured out yet what a BLDC takes to make it operate.
    When people on two different sites(that I know of) tell you the same thing and you go off on a tangent, what would you do? People on both sites will help, but you need to help yourself too.
    aqeel1 likes this.
