IR2125 highside driver
Discussion in 'General Electronics Chat' started by shortbus, Feb 19, 2013.
  1. shortbus
    Thread Starter AAC Fanatic!
    Sep 30, 2009
    4,096
    1,692
    The IR2125 high side driver has both a error and current sense in it. I don't need either one of these for my use. Is there a way to disable these?
    My circuit only uses a high side switch or I would use a half bridge driver. Can some one help?
  2. praondevou
    Jul 9, 2011
    2,936
    489
    Picture 5 of the datasheet shows that the output is shut down when CS is above a certain level. I think just if you just tie the CS input to VS it should work. Are you driving this with PWM? Do you do pulse by pulse current limiting somewhere else?
    Figure 4 says the output will be turned off when ERR rises. So I would connect the ERR input via a resistor to COM.
  3. shortbus
    Sep 30, 2009
    4,096
    1,692
    Thank you praonevou. Glad to see you posting more again.
    This is for the EDM project I've been working on for seems like forever. It is a pulsed circuit, a PWM, with both frequency and duty cycle adjustable. The PWM will give some current regulation, but for this application its not real important. It is basically a metal disintegrator.
    Could I talk you into look at another of my posts that ties into this one, please? Here's a link - http://forum.allaboutcircuits.com/showthread.php?t=81183&highlight=charge+pump Thanks.
