Ir2117 mosfet driver
Discussion in 'The Projects Forum' started by mah, Feb 21, 2014.
  1. mah
    Thread Starter Active Member
    Mar 15, 2010
    276
    i used ir2117 to drive mosfet for dc dc buck converter the input for the driver is pwm from microcontroller i attached the circuit but there is a problem the output from this driver is 9v pure dc not pwm like the input
  2. crutschow
    Mar 14, 2008
    13,520
    3,386
    Is there a voltage connected to the drain of the MOSFET? It needs one. If there already is, then you likely either have a bad IR2117 or there is a wiring error.
  3. mah
    Mar 15, 2010
    276
    i haven't connected voltage to drain , i think it should give output on the gate , there is no relation to drain.
  4. crutschow
    Mar 14, 2008
    13,520
    3,386
    The you either have a wiring error or a bad IC as I previously stated.
  5. Plasmahunt3r
    Feb 6, 2014
    28
    Gate voltage must be 10 V to 15 V higher than the source voltage. Being a high-side switch, gate voltage would have to be higher than the rail voltage.
  6. alexan_e
    Aug 8, 2010
    10
    I tried to explain (in another forum) that the problem is that he is trying to drive IR2117 input from a 0-5v microcontroller signal but according to the IR2115 datasheet (with Vcc=15v )
    anything <6v is translated as low and anything >9.5 as high.
    A 0-5v signal can't work, a level translator must be used to translate 0-5v to 0-15v.
      File size:
      47.2 KB
      139
  7. crutschow
    Mar 14, 2008
    13,520
    3,386
    So the op is apparently a slow learner. :rolleyes:
  8. alexan_e
    Aug 8, 2010
    10
    Not necessarily, we all get stuck sometimes but maybe someone else can explain it to him some other way that may help him.
  9. mah
    Mar 15, 2010
    276
    and I also tried to tell him that IR2110 has the same attached pic , however it can drive down to 3.3 volt
  10. alexan_e
    Aug 8, 2010
    10
    This is very funny, I reply in both forums :D
  11. mah
    Mar 15, 2010
    276
    do you show your self,Viewing strength ! are you proud of replying in two forums ?! so how could you explain what happenned in this posthttp://www.edaboard.com/thread219997.html while IR2110 working directly from microcontroller
  12. shortbus
    Sep 30, 2009
    4,098
    1,697
    @mah, please look at the "functional block diagram" in both data sheets.
    The 2110 has a box called, "Vcc/Vdd level shift". This is what allows the 2110 to work at down to 3.3V logic input. this level shift pulls the low voltage up to the 10V - 20V needed to change the outputs, Ho and Lo.
    Now look at the2117 diagram. It has no level shift box. This means that it takes, 10V to 20V to change the Ho and Lo.
    The part of the data sheet you showed is correct, internally both devices need 10V-20V to change. It is just that the 2110 has an internal level shift allowing it to work with lower logic voltage.
    Hope this helps.:)
