IR2111 igbt/mosfet driver IC
Discussion in 'The Projects Forum' started by umesh089, Apr 21, 2012.
  1. umesh089
    Nov 1, 2011
    i'm using ir2111s for driving half bridge of my inverter ie, for 2 IGBT's...
    but i'm not getting any pulse output for input pulses at the output.
    i've used 10uf for capacitor connected to Vcc and ather is 220pf...
    can any 1 help me out with this.... ?
    i've given the circuit diagram with this... also the data sheet is attached.....
  2. #12
    Nov 30, 2010
    16,655
    7,293
    You've given the example diagram out of the datasheet, and nothing else. Nobody can compare the example diagram from the datasheet with the example diagram from the datasheet and spot the error.
