i have a question in ir2110 ic n channel high side switch using bootstrap operation does Hin and Lin are supplied by the same pwm at the same side and the inverted signal for the other side
or
the pwm is set to Lin and inverted to the Hin at one side and at the other side the same lin and its inverter signal also
"i know about dead time"
datasheet http://www.irf.com/product-info/datasheets/data/ir2110.pdf
application note http://www.irf.com/technical-info/appnotes/an-978.pdf
or
