ir2110 low side problems?
Discussion in 'General Electronics Chat' started by aamir_sheikh, Mar 29, 2014.
  1. aamir_sheikh
    Nov 19, 2013
    11
    hi
    i am designing a bldc driver, using ir2110, and sometimes during operation the low side turns on and stays on.....does anybody has ever faced similar problems?
    attached is the schematic,
    also flyback diodes, which one should i use?
  2. MaxHeadRoom
    Jul 18, 2013
    10,873
    2,530
  3. aamir_sheikh
    Nov 19, 2013
    11
    so the problem is that pin one and pin 3 (vcc and LO) get shorted during operation, i am using 10 ohms at gate resistance and the switching frequency is 2 khz..
  4. MaxHeadRoom
    Jul 18, 2013
    10,873
    2,530
    Are you sure it gets shorted or just that pin 1 goes to 12v?
    Max.
  5. shortbus
    Sep 30, 2009
    4,098
    1,699
    Assuming your using a micro controller? Is it possible that there is a problem in your program? Is the same thing happening on all three phases? Often people blame the other components when it is a program fault.
