Hi SgtWookie.Sure, they're cheap. They're getting mighty "long in the tooth" though.
With the amount of current you're switching, it would be a good idea to keep your switched circuit portions short and thick, for low resistance and inductance. If you're using a number of MOSFETs in parallel, that will be pretty hard to do.
I mean turning just ONE of the low-side MOSFETs on continuously, and switching the high-side MOSFET on and off for PWM. You might have problems trying to keep a high-side MOSFET on continuously.
The problems you'd have with shoot-through would only occur when you change the direction of the motor from forward to reverse or vice-versa. But if you turn the MOSFETs OFF and wait for a period of time sufficient to discharge the gate charge completely (not long; 1mS would likely be enough) then you could run the motor in the opposite direction.
Be mindful about sudden motor reversal. This will place very heavy current demands on the bridge, much worse than if the rotor of the motor were locked (stalled).
Thread starter | Similar threads | Forum | Replies | Date |
G | 12V to ±80V adjustable isolated half bridge converter. | Power Electronics | 12 | |
IR2110 making a Half-Bridge | Homework Help | 31 | ||
C | IR2110 - Half bridge waveform | General Electronics Chat | 6 | |
U | Full bridge inverter using IR2110 giving output in patches | Power Electronics | 14 | |
G | H bridge problems using IR2110 | Power Electronics | 5 |
by Jake Hertz
by Jake Hertz
by Jake Hertz
