IR2110 DeadTime Inquiry
Discussion in 'The Projects Forum' started by tesla123, Sep 5, 2009.
  1. tesla123
    Sep 5, 2009
    Hi Everyone
    I am building a class D amplifier as a project in school this year.
    I require dead time in my circuit because I get ringing in the output waveform of the MOSFETS.
    I use a PWM controller chip to covert the music signal to PWM and use a XOR gate IC to split the PWM into Hi and Lo outputs and feed that into the Hin and Lin of the Gate Driver.
    I implemented dead time initially by trying the method the Application note "AN-978" said by adding a fast diode parallel to the gate resistor, but that didn't help much.
    In that same Datasheet it says
    I interpret this as I can have a Resistor-Capacitor-diode network on the output from the XOR gates and then delay the signal entering the Gate Driver.
    But I'm stuck as to where it says 10% of VDD, so does this mean If I supply VDD with a 12V supply. The schmitt trigger in the IR2110 triggers high at 1.2V?
    Or have I interpreted that statement in the application note wrong?
    Ideally I'm looking for around 100nS dead time to avoid shoot-through in the output FETS.
