IR2101 floating voltage
Discussion in 'The Projects Forum' started by onlyvinod56, Jun 15, 2012.
  1. onlyvinod56
    Thread Starter Active Member
    Oct 14, 2008
    362
    In the datasheet of IR2101 (description on first page), It is mentioned that,
    The floating channel can be used to drive an N-channel power MOSFET or IGBT in
    the high side configuration which operates up to 600 volts.
    Usually, the floating channel (Vs) is coonected in between the two mosfets in a leg. If Vdc = 600v, then floating channel voltage will be at 300V.
    How can i adjust the floating channel voltage to a desired level (0 ~ 600V)??
  2. crutschow
    Mar 14, 2008
    13,487
    3,371
    The floating channel goes to Vdc when the top MOSFET is on. Why do you say it's only 1/2 that? :confused:
  3. onlyvinod56
    Oct 14, 2008
    362
    iam saying when the mosfet is off.
  4. crutschow
    Mar 14, 2008
    13,487
    3,371
    So why do you want the floating channel voltage to be 600V when the MOSFET is off? :confused:
