IR2011 Gate driver issue- PLEASE HELP!!!!
jessie_au
Joined Nov 5, 2012
Hi people,
Im using IR2011 gate driver to drive top and bottm MOSFETs on one side of a H-bridge. The circuit I used is quite simple. Basically, im just following the circuit in its datasheet. The input signal for both high and low sides is a 5V-25kHz PWM signal. I tested the output of the driver by inputing that PWM signal to HIN and LIN separately. I can get the same PWM signal with a higher magnitude (almost Vcc of gate driver) at the the low side output (LO). BUT, the only thing I can get is roughly 11.3V DC (gate driver Vcc=12V)at high side output (HO), I also measured the source voltage of the top MOSFET, the voltage level is quite close with its gate voltage, which means the top MOSFET will never be turned ON. Can someone help me out?
praondevou
Joined Jul 9, 2011
2,942
12V - forward voltage drop of the diode = 11.3V.
Post pictures of the output gate signals.
What is the duty cycle? Where is the rest of the schematic?
praondevou
Joined Jul 9, 2011
2,942
Wait a second, are u saying the high side output is constantly ON? and there is no voltage from gate to source of the top Mosfet? Something isn't right here.
Just to make sure:
Is the voltage from pin 2 to pin 4 11.3V?
Did you measure the HO voltage from pin 3 to pin 4?
Is the Mosfet ok? Is the gate resistor ok?
jessie_au
Joined Nov 5, 2012
Hi people,
Problem solved. Because I didnt connect the load into the circuit, the high side driver remains a high output when there is no load. Once the load is switched, the problem is gone. Still appretiate those people who was offering help.
Thanks,
