IR sensor
Discussion in 'General Electronics Chat' started by minh_dp, Sep 26, 2013.
  1. minh_dp
    Nov 25, 2012
    Hi all,
    I need help identifying IR receiver sensor per attached.
    Attached picture is back, front and top view of a sensor.
    Thanks.
  2. mcgyvr
    Oct 15, 2009
    4,784
    973
    Just a typical 3 pin IR receiver..
    probably carrier frequency of 38khz
  3. minh_dp
    Nov 25, 2012
    Appreciate your input, mcgyvr. Yes, it is 38KHz IR receiver.
    It would be nice if anyone can identify the manufacturing # (datasheet) of component from the picture.
    I think it's PL-IRM0101-3 but I'm not certain. I'd like to know which pin is the output pin.
    Thanks once again.
  4. mcgyvr
    Oct 15, 2009
    4,784
    973
  5. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    So far I've yet to ever see one of those with any part No markings.
    I usually aquire mine from scrap TVs etc - if they're on a sub-panel, I leave them there and keep the panel so I can identify the pin layout when I'm ready to use it.
    GND is usually blindingly obvious, Vcc (5V) has the + side of a small electrolytic and a 100 Ohm resistor - the track to the output pin is usually the thinnest and snakes off across the board never to be seen again.
    IIRC - the output has a pull-up sesistor somewhere in the region of 15 - 20k, you might be able to identify O/P & Vcc from that, that only leaves GND - applying 5V to the O/P shouldn't do much with no Vcc to switch the transistor on, you could just get away with trial & error.
