Hello, I have the IR receiver with three pins pos neg and sig, from radioshack hooked up to my arudino. It works, but if i wanted to be able to be farther away from the receiver, what IC would i use to amplify the signal from the IR receiver.
Can you post a schematic so we can see both your transmitter and your receiver circuit?Hello, I have the IR receiver with three pins pos neg and sig, from radioshack hooked up to my arudino. It works, but if i wanted to be able to be farther away from the receiver, what IC would i use to amplify the signal from the IR receiver.
Thread starter | Similar threads | Forum | Replies | Date |
FM radio recevier | Homework Help | 2 |
Similar threads |
FM radio recevier |
