So I built an IR receiver using this: http://www.vishay.com/docs/82013/tsop12xx.pdf
where an LED lights up once an infrared signal is given, which worked perfectly. Now I want to replace the LED with a 1.5-3V basic motor: http://www.radioshack.com/product/index.jsp?productId=2102822
However, the motor does not work. And if I use a 9V battery, the receiver module heats up and the motor runs continuously. How can I make the motor run with the infrared signal?
