Well right now im feeding it 4.38 V and getting an output of 4.38 V with the window covered. Im guessing thats not right according to papabravo.a three volt output on a voltmeter would indicate either an output that is beating up and down or an output that is floating.
The device being used here is apparently not just a phototransistor. Unfortunately, it is from RadioShack, so we do not have access to a real datasheet for it, but its description and behavior are consistent with it being a 38 KHz IR detection module similar to the TSOP1738 and similar devices.I suspect you won't have much fun with the IR LED and phototransistor approach.
