IR Receiver Module Vc GND Out
Discussion in 'The Projects Forum' started by rrpking, May 19, 2013.
  1. rrpking
    Jan 20, 2013
    6
    So I just bought this IR Receiver Module from radio shack and was wondering what each of the pins mean. They say 1. OUt 2. GND 3.Vs
    Thanks.
  2. ErnieM
    Apr 24, 2011
    7,437
    1,626
    These pins are the:
    3. Vs: power supply voltage
    2. GND: the zero voltage ref of the circuit, or return of Vs.
    1. Out: signal when received. When it "sees" a 38KHz IR signal it outputs a constant lever. I don't know offhand if it's normally high and low for signal, or the reverse.
    Number 3 and 2 give the device power.
    Number 1 is what you connect to the rest of your circuit.
  3. THE_RB
    Feb 11, 2008
    5,435
    1,305
    They are almost always an open-drain pull down output, that goes low when the 38kHz IR signal is present. Being open drain they usually require a pull-up resistor on that pin, about 10k, to +5v.
    Occasionally you get one with a weak driver so the resistor needs to be higher, 33k or so.
  4. coolal
    May 19, 2013
    Hi
    i am new here and i have an urgent circuit i need help can you please message me i dont know how to message you and i ried posting a new tread but its not posting??
  5. coolal
    May 19, 2013
    Hi ernieM
  6. tshuck
    Oct 18, 2012
    3,531
    675
    Please don't spam the forum.
    Did you read the sticky on new threads? no? figures... a title I'd more than 20 characters has been known to cause errors, so chose a sorter title. Also, posts by new members are sometimes moderated before they can be posted - I think it matters which forum you are trying to post in.
    @The_RB sometimes, there is an internal pull-up
  7. wayneh
    Sep 9, 2010
    12,388
    3,244
    One problem many noobs encounter is that the output will not be held continuously low when a steady carrier is received. It will go low briefly but then turn off. They are meant to receive burst data, not to act as a switch. This behavior varies and it's hard to tell exactly what the Shack is selling at any time. If this is the Vishay TSOP4838, it does indeed have the open collector described by RB. Not sure how it responds to a steady carrier signal.
  8. Bernard
    Aug 7, 2008
    4,240
    414
    wayneh. the operation of RS, V 4838 is as you described it, needs a continuous data stream, at least as of last year.
  9. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Most of them won't resond well to continuous carrier transmission. They need the signal stream to be modulated in data pulses.
    David Cook at RobotRoom.com mentions one brand/type of sensor which does still work with continuous carrier transmission.
