I am having trouble with an IR receiver circuit design and wonder if anyone can help.
I want to be able to toggle the input to a PC serial port when an IR beam is broken. I have tried simpler circuits that only go to near 0V but these have been unreliable for me. I am trying with this circuit to get the + and - voltage range specified for RS232.
I have made a IR transmitter that outputs a modulated 38kHz to match the equirements of the receiver chip I am using - a TSOP32338 http://radio-hobby.org/uploads/datasheets/tsop/TSOP321-TSOP323.pdf
I have built a receiver circuit as attached but cannot get it to work. I separated it at the dotted line and each half works. I have removed the diode and smoothing capacitor and it works (with a 6k8 resistor where the diode was) but the output cycles at the modulation frequency.
I thought that the forward voltage drop of the diode I was using, a 1N4148, might be the problem and replaced it with a schottky BAT85 but still no go.
I would very much appreciate any thoughts.
Thank you,
Greg
Thank you,
Greg
