Yes. In the photo breadboard1a.jpg you can see the blue wire running from pin 4 to the +5vdc rail and in bradboard2a.jpg you can see a green wire running from pin 11 to the ground rail.Is there 5VDC between pins 4 and 11 on the LM224?
No, I do not think so. I'll add one.Is there a current limiting resistor built into the LED on pin 14; if not, you have to add a series resistor of about 560 ohms.
That's a good catch. I probably missed that when I pulled all the resistors to test them.The 220k resistor that is supposed to be going from pin 12 to ground doesn't look to my like it's connected to pin 12.
Yep, from the photo I would say you are correct again. I'll go verify these when I get home from work this evening.The 470pF cap that is supposed to go from pin 12 to 8 looks like it's going from 13 to 8.
