Hey everyone,
I'm looking to add electronic scoring to a bristle dartboard and my idea is to use a grid of IR LEDs and and Phototransistors. Right now, I'm just looking into putting together some hardware and then software/ interfacing will come later.
I'm a little confused on a few things regarding IR LEDs and phototransistors. First off, here are the parts I have found. By no means am I set on these, they just seemed like a cheap and simple place to start. LED and Phototransistor. My first concern is how many LED/ Phototransistor pairs would i need to get a precise enough reading on the dart's position. I'm thinking since a dart tip is pretty thin that I would need a good amount of pairss. I should also mention that the scoring area is going to be 28" x 28". I'm also worried that if the pairs are too close then light from other LEDs can bleed into a photo transistor. For example, if the path between LED 2 and Phototransitor 2 is broken, would the beams from LED 1 and 3 be enough to bleed around the obstruction, and cause phototransistor 2 to still receive light?
Thanks in advance
Mike
Thanks in advance
Mike
