IR in proteus
Discussion in 'The Projects Forum' started by karimC, Mar 10, 2013.
  1. karimC
    Feb 1, 2013
    9
    hi all,i am simulating a circuit in proteus.in my circuit i have an IR transimtter and receiver but i don't find them in the software.can you help me? plz
    thanks.
    ps:i also tried with multisim,but same thing.
  2. absf
    Dec 29, 2010
    1,493
    374
    In my proteus, there is the device "IRLINK" which is the IR transmitter and IR receiver in one package.
    I have never used it before and not sure if it would work in your circuit. For simulations you can use opto-coupler to simulate the function. Attached are the devices.
    Allen
    Syafiq Firdaus likes this.
  3. karimC
    Feb 1, 2013
    9
    what's an optocoupler exactely?
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    An IR LED closely optically coupled with a photo-transistor, but isolated entirely from each other on the electricity/signal side. They are used to isolate signals from a high voltage side of a circuit from the low side. Used in switching power supplies and other applications.
    Essentially, an IR Pair, but encapsulated into a 4 or 6 pin DIP package so outside light doesn't interfere.
    The transistor types (rather than demodulator/gate types) approximate a discrete IR Pair fairly well.
  5. karimC
    Feb 1, 2013
    9
    but i need the receiver and the transmitter to be discrete if possible.
  6. thatoneguy
    Feb 19, 2009
    6,357
    718
    They can be in the actual circuit. An optocoupler approximates one for simulation.
