IR dimmer discrete.
Discussion in 'The Projects Forum' started by franzschluter, Aug 18, 2009.
  1. franzschluter
    Thread Starter Active Member
    Jun 1, 2009
    95
    Hi guys,
    Is it possible to construct an IR light dimmer using discrete circuits? How should I go about it? My best guess is that it would look very complicated...
    I have seen 1 circuit that offers light dimming using no PICs. However SLB0586 isn't available in my local area.
    School Project Criteria... "IR Light Dimmer, NO PIC or any Microcontrollers" >.<
  2. ELECTRONERD
    May 26, 2009
    1,146
    16
    Just to make sure your IR emitter is working, you can connect it to an oscilloscope and vary the light intensity. Or you can take any digital camera and place it over the IR emitter. You should see a bright light coming from the emitter. Our eyes can't see IR but cameras sure can.
  3. jj_alukkas
    Distinguished Member
    Jan 8, 2009
    751
    5
    Making one without a PIC would make it a dumb piece of gadget. As IR code detection without discrete IR decoder IC's or a PIC, limits its code reception to 2 switches. This one is like a shift register..
  4. franzschluter
    Jun 1, 2009
    95
    yes, IR decoder IC's are allowed.. PICs are forbidden. I'm really sorry i forgot to mention 1 important factor...the circuit must be able to drive 3 lights. and dimming them individually?
    How do I go about this? Any more bright ideas? Though you gave me an idea using 1 light LED. I know using PIC will solve all these problems...
  5. jj_alukkas
    Jan 8, 2009
    751
    5
    Get the chip used in TV board's IR reception section and a couple of transistors along with the original TV remote will help you achieve what you need easily. Otherwise it will be a mess. This is your best deal. Even the chip from the remote may be used to make your own one so that the staffs wont even recogonize it.
  6. Søren
    Sep 2, 2006
    472
    28
    You could try a set of these encoders and decoders
    You still need an IR receiver and then a decoder after that.
    The transmitter should be coded by the matching encoder.
  7. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    What's wrong with using a PIC?
  8. jj_alukkas
    Jan 8, 2009
    751
    5
    For school mini projects on Digital electronics, it is a standard to not allow to use microcontrollers. The main project which comes later however must be done using microcontrollers. It was so for me for Electonics Engineering.
