1. RRITESH KAKKAR
    Thread Starter Senior Member
    Jun 29, 2010
    2,831
    89
    Now I am working on IR decoder for remote control.
    I have sen some Universal remote which accept all command of other remote and work as per there command, anyway i need to make control system using 877A to decode TV remote control signal can any remote will work?
      File size:
      4.1 KB
      11
  2. Shagas
    May 13, 2013
    802
    74
    Can any remote work as what ? The sender or the reciever ?
    What is the 887A ? Is it a micro or the module that you linked in the picture ?
    I don't know about how standardised remote signal carriers are , but If you are using that TSOP reciever module that you have in the picture then you have to make sure that the remote carrier matches the reciever carrier.
  3. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    The sender...and PIC16f877a .
  4. Ramussons
    May 3, 2013
    562
    92
    Seems RRITESH KAKKAR wants to make a Universal Remote Control using PIC16f877a that can be Programmed to the Control Codes of Any Remote.
    Should be possible, not my area :mad:
    Ramesh
  5. ErnieM
    Apr 24, 2011
    7,443
    1,628
    Did you ask Google to see if anyone has ever done this before?
  6. Shagas
    May 13, 2013
    802
    74
    Well as I said , you want to generate an accurate carrier and use a 980nm Ir diode and the programming is up to you...
  7. Ramussons
    May 3, 2013
    562
    92
  8. Jibby
    Sep 12, 2013
    15
    Yes, it will work with any remote.
