IR body tempreture sensor.
Discussion in 'The Projects Forum' started by ecjohnny, May 5, 2008.
  1. ecjohnny
    Thread Starter Senior Member
    Jul 16, 2005
    142
    Firstly.... sorry if i started another topic because i think its quite different from the one a few thread below(mine) to avoid confusion. Also i hope to get a reply soon on that thread.
    Here... is there any product like this (topic name). i want a sensor or some device that can measure a person body temperature at a certain distance?? Any product that does this or similar??
    i search Google and it couldn't help me much. maybe i am not well-knowledge enough. Prove that i am retarded please... i dun mean it :X :p
    Thanks Bro and Sis...
  2. KMoffett
    Dec 19, 2007
    2,584
    234
    ecjohnny,
    Details!...details!...details!...The devil's in the details!
    What temp range? (37°c±3°?)
    Accuracy? (±0.1°C?...±0.01°C?...)
    Response time? (mSec?...Sec?...)
    Distance? (mm?...cm?...meters?...)
    Output? (LCD?...digital?...analog?...)
    Ken
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    One other detail: Are you asking for body core temperature or surface skin temperature?
    Skin surface temperatures can be quite variable. Core temperature is usually measured at a protected site, such as under the arm, external auditory canal/ear drum, mouth, etc. For the latter there are numerous non-contact, IR thermometers available. There is no reason such thermometers can't be aimed at the bare skin.
    A big problem will be the ratio of the area sensed to the distance of the sensor. Inexpensive instruments have a fairly broad capture and the area sensed becomes too large and is virtually useless at a distance of few feet. John
  4. kender
    Jan 17, 2007
    263
    Yes, I saw a contactless medical IR thermometer for body temperature. They were used for screening in Asia during SARS epidemic few years ago. As Ken mentioned, they are good for skin temperature. Of course, you can still tell whether or not the person has a high fever. Skin temperature on the forehead is close to the core temperature, especially is the ambient temperature is 20C or higher.
    I have an industrial contactless thermometer. It's calibrated. It reads 35C on my forehead. The ambient is 21C. I'm wearing pants and short sleeves.
    - Nick
  5. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    There is a factory not far from my home which makes forward-looking infrared cameras for the military and for industrial applications. There is a print hanging in their lobby of some folk hiding amongst thick foliage. The folk stand out quite clearly in the IR image.
    Here's their website: http://www.flir.com/US/
  6. ecjohnny
    Jul 16, 2005
    142
    body temperature ... fever/sick or temp falling.
    accuracy ... not sure like thermometer used in clinic will do.
    Response .... Seconds will do.
    Distance ..... short IR distance
    Output .... to a receiver .
    i am getting the body temp of a person from a distance (IR) then transmit it to the receiver.
    Also... dont know if anyone good in medical knowledge, will a person body temp fall if he/she faint or the heart attack/ related.
    Thanks for the help... pls refer me to the product page if it exist.
  7. jpanhalt
    Jan 18, 2008
    5,699
    909
    Why not just use a inexpensive, drug-store, IR thermometer designed for home (and clinic) use? That would require the person's consent, of course.
    If you intend to do this thing without the individual's consent and you are in the USA, I suggest you look up legislation that is known by the acronym HIPPA (http://en.wikipedia.org/wiki/HIPPA). That legislation is intended to protect personal health information (PHI), which includes among many other things, a patient's identity and any related health information. Moreover, ethics in research require prior approval by an Institutional Review Board (IRB) for any study that is not done in the normal course of care for a patient.
    One area of confusion among some investigators is whether one must get IRB approval for research that is non-invasive. In other words, something as seemingly harmless as taking a pulse or temperature may be consider non-invasive and not require informed consent. However, that decision needs to be made by an IRB, not the investigator. Doing it without IRB approval is itself an offense, regardless of whether demonstrable harm to the person was done.
    It has become a complex area. Before I would do anything like you suggest without consent, I would certainly read up on the matter. The real hook is not so much the Federal and State fines and penalties, you can be sued directly by the individual.
    John
  8. KMoffett
    Dec 19, 2007
    2,584
    234
    Distance? Be specific! In almost all IR temp sensors, the area being measured varies at the square of the distance. At 0.5 meter you might be measuring on an area 2 cm in diameter. At 1 meter it would be 4 cm in diameter, and at 2 meters it would be 8 cm. So the actual distance to your target is very significant to the sensor's spec'.
    Transmitter/Receiver? Wireless?...wired?...PC?...microcontroller?
    Ken
  9. ecjohnny
    Jul 16, 2005
    142
    Sorry guys... i just realize that i got the IR wrong. i mean IR wouldn't work for my system. Anyway it just some thinking.
    Heres the diagram. The "Blue" one is the device that i mean. if that device exist pls link me.. or guide me. Forget about the range all.... Does such product exist? i am not making it, i am asking if anyone come upon such product. i am buying for some modification to my existing system. So the range and all i will decide after looking into the product.
    Thanks a lot.
  10. Digi Dave
    Member
    Apr 25, 2008
    26
  11. jpanhalt
    Jan 18, 2008
    5,699
    909
    That seems awfully expensive compared to comparable imports in the USA. My IR thermometers were less than $10 each at Harbor Freight.
    Moreover, note:
    So, the sensed spot grows very fast with distance. That's what I meant in my earlier post that at any distance greater than a few feet, the spot gets so large as to be basically a measure of room temperature. John
