Ir audio transmitter and receiver
Discussion in 'The Projects Forum' started by stupidguy123, Sep 25, 2011.
Thread Status:
Not open for further replies.
  1. stupidguy123
    Sep 25, 2011
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    I have seen that old circuit before on other websites. I don't think the transmitter works because its first transistor has no base bias current and the red LED shorts the audio signal.
    The first two transistors in the receiver are a preamp and the 3rd transistor is a class-A driver for the low impedance headphones.
  3. stupidguy123
    Sep 25, 2011
    yup, i know we should add a source to make a base current. but the second part still not work........do u know??
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    The transmitter circuit is a total disaster.
    In addition to the first transistor missing its base bias current the red LED is shorting the audio signal so the second transistor in the transmitter does not modulate the current in the IR LEDs.
    The receiver circuit is also a total disaster.
    I forgot to mention that the receiver puts DC through the headphones which might cause them to burn out.
    The circuit comes from a website in India where almost all circuits do not work.
    http://www.electronicsforu.com/electronicsforu/lab/freecircuitslist.asp?id=26&title=Infrared Cordless Headphone
  5. ojaswi
    Apr 14, 2015
    can you explain the circuit in detail including how all the values are chosen
  6. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    old thread, now dead.
    The topic starter can always ask a moderator to open the thread again.
Thread Status:
