Ir and phototransistor
Discussion in 'General Electronics Chat' started by Kaiser Ed Bayawa, Feb 14, 2016.
  1. Kaiser Ed Bayawa
    Mar 19, 2015
    60
    6
    I have here an ir and a phototransistor but I dont know what is its code.. can you please give me a circuit how to use this?
  2. DickCappels
    Aug 21, 2008
    2,779
    674
    Not without more information.
    Can you describe the parts in details, perhaps by part numbers and/or photographs?
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  4. Kaiser Ed Bayawa
    Mar 19, 2015
    60
    6
  5. Kaiser Ed Bayawa
    Mar 19, 2015
    60
    6
    i dont know the code of this transistor but i know the pinouts are..
    see my attackment photo, the output of my photo transistor cant trigger the 6v relay.. can anyone here help me with this..
  6. andre_teprom
    Member
    Jan 17, 2016
    31
    9
    TSOP38238 ?
  7. GopherT
    Nov 23, 2012
    6,326
    4,055
    Those IR sensor modules require the incoming IR light to be flashing at 38000 Hz. That way, sunlight shining in the window or light bulbs don't trigger them.
    Check if you can get the output pin to trigger with a remote control from your TV.
  8. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,705
    1,300
    That is not a transistor. It is an integrated circuit with an IR photodiode, amplifier, level sensor, and open collector output driver. Probably.
    ak
  9. DickCappels
    Aug 21, 2008
    2,779
    674
    Moderator's note: Posts #5, #6, #7, #8 were moved to here from another, essentially duplicate, thread. Please do not start multiple threads for a single question.
  10. Kaiser Ed Bayawa
    Mar 19, 2015
    60
    6
    sir using the tv remote i can trigger the phototransistor. but it wont work using the relay
  11. Kaiser Ed Bayawa
    Mar 19, 2015
    60
    6
    how can i use it to trigger a 6v relay?
  12. DickCappels
    Aug 21, 2008
    2,779
    674
  13. Kaiser Ed Bayawa
    Mar 19, 2015
    60
    6
    using the photo i've sent how can i determine the emitter base and collector of the phototransistor?
  14. bertz
    Member
    Nov 11, 2013
    239
    32
    As Analogkid has already explained to you, the device you have is NOT, I repeat is NOT, a phototransistor. It is an IR decoder based on the Sony SIRC protocol. It is typically used in conjunction with a microprocessor as a remote control device. Perhaps if you gave us more information about your intended use we could be more specific about possible solutions. I have attached a datasheet which will give you the connection scheme and some application notes.
  15. Dodgydave
    Jun 22, 2012
    5,163
    774
    Kaiser, are you related to Rittesh by any chance...:confused:
  16. Kaiser Ed Bayawa
    Mar 19, 2015
    60
    6
    No sir.
  17. Kaiser Ed Bayawa
    Mar 19, 2015
    60
    6
    Thank you for your help sir. The circuit im looking for is done. I made a research about latch switch,Darlington connection, and the ir decoder. Combining these circuit came up into remote controlled switch.
    DickCappels likes this.
