ip address
Discussion in 'Computing and Networks' started by chandrasekhar, Nov 24, 2010.
  1. chandrasekhar
    Nov 5, 2010
    13
    my ip address is 10.21. #. #.when i enter in "whatsmyip" website ,here it shows me "129.123.#.#".how can there be an two different ip address for 1 user. :)
  2. nerdegutta
    Dec 15, 2009
    2,565
    805
    HI,
    I think that the 10.21.x.x address is you local ip adresse, assigned from modem or router. While the 129.123.x.x address is the address your modem or router got assigned from your ISP. It's the modem or routers address whatsmyip can "see".
    chandrasekhar likes this.
  3. AlexR
    Jan 16, 2008
    735
    54
    10.X.X.X is one of the private IP addresses. It allows you to set up a private network but the network address is never routed and never advertised over the internet.
    Your router performs network address translation to connect your computer to the internet. All outgoing IP packets use the router IP address as the source, all incoming packets are addressed to the router.
    The router keeps track which incoming packet is destined to which local host and replaces the destination address (its own address) of incoming packets with the appropriate local host private ip address.
    So to put it simply the 192.123.x.x address you are seeing is the router link IP address.
