The Blue Power Light comes on, then it immediately switches over to the Red "Clean" indicator light.
Cleaning didn't help, so I powered off, disassembled (being aware there is high voltage inside) and cleaned the wire strands with fine emory cloth, and reassembled, and that didn't help.
Next, I disconnected and pulled the main board, but I don't see anything obvious, nor do I smell anything burnt.
Has anyone had any experience with these, that they might have a clue as to what could be causing it to default to the Clean mode immediately?
If not, I will probably test components one by one (60 plus parts), or if not that, then I'll scavenge it.
Thanks,
Gary
Thanks,
Gary
