Hi.
I'm currently working on a robot that needs to stay inside a small area, the area is limited by a invisible fence which frequency is of 10 Khz, the problem that I'm facing is that adding a coil on every side of the robot in order to detect the fence will take a lot of space (if you count the space needed for each one of the circuits for each coil). The frequency is generated from an underground cable.
Thanks for your time.
