Invertors
Discussion in 'General Electronics Chat' started by Garth, Jul 20, 2014.
  1. Garth
    Jul 19, 2014
    5
    I have a 2,000 watt Invertor.. If I run an 32 watt fan, how many watts or amps is the 2,000 watt Invertor using from the 12 volt battery ?.
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    The consumed power will be higher that the 32 watts of the fan alone.
    The inverter will have an efficiency, most likely given in the documentation of the inverter.
    An invereter can have an efficiency between 80 and about 90 %.
    Lets assume an efficiency of 80 %, than the power taken from the battery will be 32 / 0.8 = 40 watts.
    Bertus
  3. crutschow
    Mar 14, 2008
    13,505
    3,376
    The efficiency may be less for light loads. It depends upon the quiescent no-load current of the inverter.
  4. Brownout
    Jan 10, 2012
    2,375
    998
    Here's what I do. I connect a battery charger and note the current. Then I connect the inverter and load and take another reading. Subtract the first reading from the second and you know the current draw.
