Hey guys,
Im new to this site and am definetly not an electronics genious by any means. We are a perfomance shop that builds mostly all diesel race trucks.
Now for the problem, we have swapped injecion pumps on a truck to a different model. They are both pwm controlled on the ground side. the factory pressure regulator(solenoid) is normally open. On the new one its normally closed. So basically I need to invert the signal and am having a hell of a time figuring this out. Its a 12v system, both regulators are operating at 330hz.
I tried irf510 without any luck there. I right now have 2 tip3055's in parallel. I have a diode accross the solenoid. The signal appears to be inverted however its not a good signal. Seems when it shuts off the signal falls to 0v then imediatly ramps up to about 9v then up to 12v for the on time. I dont know how to clean the signal up so the off time is actually off.
I could be going about this totally wrong.... thats what im not sure, i just dont have any help at all from anybody on this one. Any help would be much appreciated. Thank you very much.
