Inverting Op-Amp
Discussion in 'Homework Help' started by need_help, Jan 27, 2010.
  1. need_help
    Sep 7, 2009
    23
    It has been a while since I learned Op-Amps. Can someone please direct me how to solve this problem.
    Vin= +1V
    Find Vout, I1, I2, I3,I0
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. StayatHomeElectronics
    Sep 25, 2008
    864
    40
    For an ideal op-amp, the voltage at the V+ and V- terminals are equal and the current into the amplifier at terminals V+ and V- is zero.
    Knowing the voltage at V+ gives you the voltage at V-. Now you can find the current I1. And so on...
  4. need_help
    Sep 7, 2009
    23
    Since V- and V+ are O volts and no current.
    I1=I2=(Vin-0V) / 1K = 1mA
    Is this also equal to I0?
    And how about I3?
  5. StayatHomeElectronics
    Sep 25, 2008
    864
    40
    Calculate the voltage across the resistor with I2 running through it. Find Vo.
    Knowing Vo also lets you calculate I3. Now, what is I0?
  6. need_help
    Sep 7, 2009
    23
    So Vout= 10K * 1mA = 10V ???
    I0 is the current coming out of the op-amp. does it equal to 0V ???
    If Vout is 10V, then I3= (10V-0) / 10K = 1 mA ???
  7. StayatHomeElectronics
    Sep 25, 2008
    864
    40
    Getting closer...
    Be careful with the direction of the current and the voltage that are derived from it.
    HINT: don't forget this is an inverting amplifier...
    What is Vo?
    Be careful with the sign on the current for I3 as well.
  8. t06afre
    May 11, 2009
    5,939
    1,222
    IO has to be the sum of I2+I3. And I2 and I1 must have opposite sign
  9. StayatHomeElectronics
    Sep 25, 2008
    864
    40
    Following the convention in the diagram, I1 = I2 and I3 = I2 + I0.
    Now, the sign on the calculated currents must be maintained to the same convention for the answer to be correct.
  10. need_help
    Sep 7, 2009
    23
    V(R2) = Vi * (R2/R1) = 1V*( 10K/1K) = 10V
    Vout= -V(R2) = -10V Is this OK?
  11. Paulo540
    Member
    Nov 23, 2009
    188
    Yes, you have a gain of '-10'. due to the 10:1 ratio of resistors, and - because its an inverting input.
  12. StayatHomeElectronics
    Sep 25, 2008
    864
    40
    Vout does equal -10V.
    I1 = (Vin - 0) / 1k = 1mA
    I2 = I1 -- since current into a node must equal current out of the node and the opamp draws no current at V- terminal.
    V(R2) = 10k * 1mA = 10V
    Vout = -10V -- based on defined current from positive to negative voltage, and left side of resistor is at 0V.
    Now I3 and I0 are the only things left. Be careful of which way the current is defined in the diagram.
  13. need_help
    Sep 7, 2009
    23
    I3= (0-(-10V)) /10K = 1mA
    I0 = I2+ I0 = 2mA
    Is this correct?
  14. StayatHomeElectronics
    Sep 25, 2008
    864
    40
    Since Vout = -10V
    I3 = ((-10V) - 0)/10K = -1 mA -- based on the direction of the current arrow designated in the problem.
    I3 = I2 + I0
    which is equivalent to :
    I0 = I3 - I2
    I0 = - 1mA - 1mA = -2 mA
    The minus sign on the current indicates that it is in the opposite direction of the arrow, or in this case, being drawn into the amplifier. The amplifier is sinking the current and not sourcing it.
  15. StayatHomeElectronics
    Sep 25, 2008
    864
    40
    Once you draw a current arrow from let's say A pointing to B, make sure you do the current calculation the same way.
    I = (V(a) - V(b)) / R
    A - sign means the current is in the opposite direction. As long as you keep the same convention throughout the problem, the + and - signs will work themselves out and you don't have to remember which way the current is defined for each part of the problem.
  16. need_help
    Sep 7, 2009
    23
    Thank you for the explanation.
