PeterCoxSmith
- Joined Feb 23, 2015
- 148
high gain, high values of resistance and changes in temperature make a difference, which can be estimated as worst case from the data sheet. Try running your tests cold and hot, using your freezer and your oven. You might also like to try a different circuit more susceptible to bias currents like an integrator.it doesn't seem to make much difference.
