inverting cuk output
Discussion in 'The Projects Forum' started by Hemamalini, Jan 9, 2009.
  1. Hemamalini
    Jan 9, 2009
    i am doing a project using cuk converter.I need to change the output from negative to positive(-30v -+30).I have used op-amp741,which gives maximum of 10.75 only.kindly give me a suitable solution.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  3. Hemamalini
    Jan 9, 2009
    I have designed cuk convertor separately.The output is negative ,but positive output is needed for our project.For that i have implemented inverting amplifier (741),its maximum output in datasheet itself is 10.75v,But i want more than 15v.kindly provide suitable suggestion.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    A 741 opamp is a very old design.
    However, it should still be able to get within 3v of the positive rail, but typically within about a volt - unless your load is less than 10k Ohms.
    Since you say you have already made a Ćuk converter, and it's output is negative, what is the voltage of the positive (supply) rail that you are starting off with?
