inverting amplifier
Discussion in 'General Electronics Chat' started by PG1995, Aug 12, 2011.
  1. PG1995
    Thread Starter Active Member
    Apr 15, 2011
    753
    5
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    Here is a link to a datasheet for the LM741; an ancient opamp (40+ years old) but still in use, mostly by the educational system:
    http://www.national.com/ds/LM/LM741.pdf
    There is a schematic of the opamp on page 4. You'll see that on the inside, it's mostly transistors, some resistors, and a few capacitors.
    That triangle symbol is used for both operational amplifiers and comparators. Comparators are similar to opamps, but different; opamps are used more for accurate amplification of signals, while comparator outputs change states very rapidly when the input voltages cross each other. Opamps are sometimes used as comparators, but they are much slower than the real thing. Comparators make very poor opamps.
    Here is an animated tutorial on opamps:
    http://holbert.faculty.asu.edu/ece201/opamp.html
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
  4. PG1995
    Apr 15, 2011
    753
    5
    Thanks a lot, Sgt.
    @Bertus: Thank you for the link.
