Think of the feedback resistor that will be required.Gain=Rfeedback/Rinput
Gain is known.
Rinput is known.
Solve for Rfeedback.
Then wire it up like this:
The input resistance of op amp itself is usually in MegaOhms. As in Millions of Ohms. Get it?What would be a recommended op amp to use? And can the input resistance of 10k mean the input resistance of the op amp?
The input resistance of an amplifier is the resistance as seen by whatever is driving the amplifier's input. For some opamp-based topologies it is the input resistance of the opamp, but in most it is not. That includes the topology that shteii01 recommended.What would be a recommended op amp to use? And can the input resistance of 10k mean the input resistance of the op amp?
No, that was not the main point. Since it hasn't been said what the max signal frequency is, that GBW product may or may not be an issue.The main point of WBahn's is that if you have input signal higher than 1 kHz, you will have problem. The op amp in this situation acts as a simple filter. It simply filters OUT any signal that is higher than 1 kHz.
